Context
We currently have one field, Comments, which is acting as a catch-all for various pieces of information. There are various pieces of information that could go in there, and we currently get a mix of problem, diagnosis, and solution mixed together (if included at all).
Constraints
- We get quite minimal information added into the comments field at present
- Average word count is ~6 words. Over 1700 devices with empty problem description. Over 2700 with between 1 - 4 words.
- We have to strike a balance between capturing the data in exactly the format we need and overwhelming people with too many fields for data entry. Good UI/UX can help alleviate ‘field overload’.
- ideally, we’d have a set of predefined problems/solutions/etc per category, rather than relying on freetext input at all, which always brings its own issues - this is a wider ORA question
Design decisions
Spreading the load of data capture between hosts and Restarters should help improve the data capture, particularly asking for further input by Restarters after the event has finished.
Possible pieces of data capture:
- Problem as reported by the participant (i.e. self-diagnosis, e.g. ‘it doesn’t turn on’)
- Problem as discovered by the repairer (i.e. diagnosis, e.g. ‘dead hard drive’)
- Solution if discovered
You could argue that both participant and repairer could contribute to both cataloging the symptoms and providing the diagnosis of the problem. It’s perhaps not as simple as problem/diagnosis/solution.
The ideal would be for a given category of product (and possibly even model of product), to provide dropdowns/suggestions for each of these, although to be begin with it will continue to be freetext.
Possible analysis
What are some could stories we could tell with this data available?
Changes to existing data
As and when new fields are added, some post-hoc data scrubbing would be needed to analyse the comments field and to break it up into its constituent parts as per the new fields. It wouldn’t have any affect on environmental statistics.
