At the Repair Cafe a customer brought in a PURE radio with a broken on/off/volume switch. Having taken it apart (by trial and error since there is no service manual available) we diagnosed the exact part that needed replacing. A request to PURE was made as below:-
I volunteer at a local Repair Cafe and have a Pop Midi to repair. The rotary encoder centre shaft has broken, and the on/off/volume button has therefore become detached. Can you supply a replacement so I can remove the broken one and solder in the new one?
Their reply:-
Thank you for your email! We are sorry that the rotary encoder of the Pop Midi has broken. We understand how unpleasant this may be.
We are afraid to inform you we can no longer offer any repair services or spare parts as this would not be economical.
We apologize for any inconvenience this may cause.
However, if the device is within warranty, we suggest returning it to the place of purchase for a replacement or a refund.
If the device is out of warranty and you wish to replace it, we can offer you a 20% discount on products from our Pure Shop. Please note that the discount does not apply to refurbished or discounted products.
If you accept the offer, let us know and we will assist.
We hope this helps.
Best regards,
Customer Support
Pretty rubbish in my opinion, so I pursued them further:-
Thanks for your message.
Can you provide a parts diagram for the rotary encoder so I can ensure I buy the correct sized item? I believe itâs a 30 position detent version with an 11mm square base, but I donât know the total shaft length.Kind regards
Mark
Their reply:-
Hello Mark,
Thank you for your reply.
Unfortunately, it is Pure policy not to supply any user-serviceable parts, schematics, or repair diagrams for any of our models, inside or outside of warranty, due to confidentiality.
We apologize for any disappointment caused.
We thank you for your understanding.
Best regards,
Customer Support
I think itâs a very disappointing response. Thereâs no confidentiality issue in providing the spec for a rotary encoder and is just a way of obfuscating in the hope of selling another new item.
To put this in perspective, I recently repaired a Philips boom box from the 1980s. A full service manual was available online detailing the procedure for dismantling, cleaning, lubricating and reassembling. Every screw was listed and its dimensions stated.
PURE should feel embarrassed with their approach to sustainability. I sourced the part online and replaced it - a pretty easy job. I shall mention PUREâs policy to all who will listen.
