Wirecutter recently updated its reviews of “best” toasters, and included a very interesting section comparing design and materials used in current cheap/unrepairable toasters with toasters dating back to 1918 to 1930s (!). Lots of learning about durability of various alloys used in different products. I was however a bit disappointed that Wirecutter accepts toasters’ disposability based on their low cost
In the same piece they also review a (very) expensive Dualit toaster, not mentioning that it’s fully repairable, but concentrating on how it doesn’t make the best toasts anyway, despite the high price
Anyway, I’d love to hear comments by Restarters, especially those of you who have attempted repaired toasters
Who knew there was a Toaster Collectors Association. Is that for working toasters only?
I repaired my toaster, was a mechanical failure where a plastic tab had slipped out of position so the toast carriage wouldn’t hold down.
Being a little sceptical about blanket statements like “toasters aren’t made to last like they once were.” - are there stats to back that up? Citing surviving vintage toasters as evidence that vintage is somehow “better” than modern seems somewhat of a stretch; yes some can survive a long time, but I don’t see stacks of working vintage toasters around to support the generalization.
Yes - as far as I know the Dualit is fully repairable… the initial expense of the Dualit includes the cost of maintaining and making stocks of parts ‘for all time’ and sometimes in quite small quantities at reasonable prices, and the ordering and postage departments involved.
Of course the original design (from an engineering point of view) is critical… I well remember the family toasters [Morphy Richards] in the 1960’s, which were forever jamming, burning the toast, and burning out the miserable solenoid which operated the release (I had to rewind the coil for that). In the end we gave up, and bought a German ‘AEG’ toaster - a much better design, which has run for 50+ years. The key was more initial thought to the engineering and design, a cooler-run element ( no burn outs; crunchier toast) and better construction… these are not very ‘costly’ differences.
In the 1960’s as a schoolboy, I used to frequently repair ‘drop-side’ toasters using the little nickel cathode tubes from spent radio valves, to crimp the broken ends of elements together. The element always ran just a bit hotter afterwards! People were for ever poking the elements with forks and making short-circuits!
That said, Beach told us it would be unlikely for the heating elements to be the main cause of malfunction. He said the more likely scenario for failure would result from an electrical malfunction, such as a delicate solder joint that breaks and causes an electronic component to give out.
I have probably done about 10 toasters over the last couple of years and there are only one has failed in this way. Of the remainder:
80% have crumbs stuck in the mechanism and only need cleaning
The remainder have burnt out heating elements which need replacing (usually costing more than a second hand toaster)
I have a four slice chromium swan in a box waiting for me to get a steel spring piece fabricated, it’s well made with the shiny chrome so should be able to last a fair while longer and last week I did a friends toaster, sucessfully. It was a piece of junk, cheaply made yet with security screws in deep holes to make it hard to get apart. when I got in I found it’s pressed soft metal arm had become bent and was stopping the main switch from closing.
A bit of “bendinage” and cautioning the owner to use a finger tip and feel for the latch was all it needed to be ready to start making toast again…
