iCal calendar feeds
🛠-in-development
Missing functionality: iCal feeds for groups. It would be good to have an iCal feed for all subscribed groups at the minimum.
Having the possibility to add groups to the feed even when not subscribed to them could be useful but may be too complex (for when you’re interested by a group but have not decided yet to join it - so basically at that stage all you want is notifications of events and you may decide to subscribe to the group or stop notifications after having been to one event). If you decide to implement the latter, then it would be useful to have super-selections i.e. for all the London groups (same as Meetup).
If the aim is to eventually switch off Meetup, this feature would need to be in place beforehand; it is an essential feature (currently of Meetup) for me and likely for many others too.
Thanks @Panda - very good idea.
I’ll add an item to the Roadmap for iCal feeds.
In discussion with @Ten, we’ve determined this is super important to help share events with event organisers, volunteers and people who do not use Restarters.net. It would also help here at Restart HQ, as we have to copy over every single event, by hand, to our shared Google Calendar.
Any chance we can bump up its priority?
Yes we can put it in to the next round of developments.
So I suppose there’s two different approaches to this. I think @Panda you’re suggesting that if you’re a registered member of restarters.net, you get one feed tailored to you (based on which groups you are a member of) - is this how Meetup works? I think @Janet you’re suggesting a publicly accessible feed for each group, and also a megafeed of all groups for use in HQ. Correct me if I’m wrong both.
I think the second approach could work for your use case @Panda - though the onus would be on each individual to navigate to each group they are interested in and add each group iCal feed to a personal calendar. One thing that the second approach would not help with is a feed of which you have RSVPed to or not, but I’m guessing that’s not too important.
Close!
My suggestion:
One feed for the groups you are member of. This is private by definition as linked to a user.
A feed for a location (i.e., one for all of London - that’s what the meetup feed is). This could be public and would benefit from being public.
I also think Janet’s option of one public feed per event could be useful.
Bonus extra option I had mentioned:
Having a feed builder, i.e., you select which events or location you want in your feed. However this is likely much more complex to build and the potential use is likely small.
That’s reasonably straightforward in terms of building the feed, although I wonder what the mechanism would be for authenticating to a private feed from a calendar app? Wouldn’t want to have user/pass on a URL. Could make it a unique, unguessable id, but that is security through obscurity which is not great. (That said, it’s not particularly sensitive info.)
Hmm, need to think how best to implement this - I guess it works for the Restarters London Meetup group because that’s one group in Meetup, to which we add all London events. Whereas we have multiple distinct groups in restarters.
Some existing mechanisms we could potentially use for grouping together groups by location: the geocoding of a group’s location; the ‘Area’ field, though we’re currently in discussion about whether to keep this; group tags, but these are only addable/editable by admins at the mo.
Do you mean one public feed per group, or perhaps am I misunderstanding?
It’s not sensitive info. A unique id would do the trick. Hopefully this would work without the need to log in so no restarters password would have to be used in the feed aggregator.
An area field sounds useful, though tags may be more flexible. Someone would need to be in charge of maintaining/updating the that grouping, whichever way it’s implemented. New groups don’t appear everyday everywhere so it should take little responsibility for an ‘area coordinator’ to maintain that list.
That’s how I understood it.
@panda Would be interested on your thoughts how to treat events you’ve RSVPed to. What does meetup do here? (e.g. does it show you all events for your groups, and flag in some way those that you’ve RSVPed? Or can you get a feed of just those you’ve RSVPed?)
What would we do with past events in the feed? I would guess keep them in the feed just for reference?
@james @Janet what are your thoughts on producing a calendar feed for a particular area?
In the context of a feed, the RSVP status is not critical. Meetup doesn’t do anything about it. Ideally you could add in either the title (if not already too long) or the description a tag/flag/keyword such as ‘confirmed’ or ‘attending’ so one can remember when checking their calendar.
The current feed from Meetup just remove past events from the feed. The previous feed (IIRC it was from Google) did keep past events. Getting rid of past events would reduce the size of the feeds so may be better for the load of the server, or maybe it’s such small volume even with many people subscribing to feeds that it doesn’t make much difference?
#12
So this thread is about feeds, but wouldn’t be a big (and easier) win to be able to generate a calendar entry per an event? (also commitment free! :joy:)
(on a personal workflow level I have to add it to the office calendar…and Ellie (and Jon?) also maintained a spreadsheet…)
meetupical meetupicalmenu
google calendar is just a big url…there must be libraries/ plugins for this?
https://calendar.google.com/calendar/r/eventedit?location=3Space+International+House+-+Canterbury+Cres+-+London,+gb&sprop=name:Women+repairing+electronics:+Rosie+the+Restarter&sprop=website:https://www.meetup.com/Women-repairing-electronics-Rosie-the-Restarter/events/258278733&details=For+full+details,+including+the+address,+and+to+RSVP+see:+https://www.meetup.com/Women-repairing-electronics-Rosie-the-Restarter/events/258278733 Having+identified+gender+balance+as+a+challenge+in+our+pool+of+volunteers,+we+organise+skillshares+r…&text=Skill+share+on+Basic+Electronics&dates=20190207T183000Z/20190207T210000Z&sf=true
#13
the only argument against this that I can think of is a UI/UX flow one…we want people to click attend (assuming they are logged in…) before they calendar it?
#14
Definitely straightforward to generate the Google eventedit link for individual events. It looks as if it has location, name, details, website, start/end datetime (and an extra ‘text’ field?)
Is it enough to support GCal? Would it alienate users using a different calendar? What do the other calendar links do?
Where would you place it in the interface @Ten? (underneath the date/time like in meetup seems sensible)
Out of interest, what happens if the details of the event change in Meetup, and you click the link to add it to Google Calendar again?
#15
Bumping this thread to gauge interest - please vote if you would find iCal calendar feeds useful!
#16
Per-event adding to calendar has been added in now :+1:
Work on full iCal feeds is scheduled to begin in May.
